[Solved] Bulb control
Posted: 16 Aug 2019, 11:59
by FalCT60
When set to Bulb, there seems to be no way to trigger the shutter : if pressing the camera symbol, it displays a menu with hms settings instead of opening the shutter. Next tap would ideally release it. Just like a classic remote control.
Thanks in advance,
J.-L.
Re: Bulb control
Posted: 20 Aug 2019, 06:56
After you select the 'BULB' shutter speed and press the 'Capture' button you will get a dialog where you can set the BULB time or just press the 'Capture' button where you will present with a counter and a 'Stop' button that you can use to stop the BULB capture.
Re: Bulb control
Posted: 20 Aug 2019, 16:48
by FalCT60
Yes for the menu : it appears when I press the camera icon (= the capture).
No for the next : pressing [Capture] (left to [Cancel] and [Clear]) does nothing but returning to the main screen.
Unless I did miss something very obvious.
NB : LV button has no effect either in Bulb mode.
Rgrds,
J.-L.
Re: Bulb control
Posted: 21 Aug 2019, 06:36
On what camera?
Re: Bulb control
Posted: 21 Aug 2019, 12:36
by FalCT60
Nikon D700.
Works with the D4s.
Could not get ahold of the cable for 1v1, so not tested yet.
Re: Bulb control
Posted: 21 Aug 2019, 14:19
The D700 does not have the required remote command to activate BULB mode.
Re: Bulb control
Posted: 21 Aug 2019, 21:13
by FalCT60
OK, so neither a feature request, nor a bug...
Thanks for all,
J.-L.
BTW : I will have to test thoroughly what does or not work with each of my cameras...
