I've installed DDserver on Raspbian. It works ok if I try to connect trhough ethernet, but if I want to connect via wlan (wlan0), qDslrDashboard doesn't find my camera (I've a Nikon D7000).
Please, Could you help me to find the problem? Could I run DDServer in debug mode? Could you provide qDslrDashboard to select DDServer manualy?
Thanks,
NOTES (to solve my problem):
-By default, qDslrDashboard is configured to connect at 192.168.1.1:4757, and I've configured my RaspberryPi WiFi with another subnet. When I changed the WiFi configuration, qDslrDashboard connects without problems!!
-Another way is connect through your configured IP server (try a long press in 'Network' button and enter the correct IP address where DDServer is, and press the 'Connect' button).
And my Feature Request:
-Run DDServer in debug mode.
-Know the version of DDServer you have installed (in CLI).
Thanks for your job!!!
