Anyone successfully using qDSLRDashboard on a Galaxy S8?
Posted: 20 Jun 2017, 02:56
I don't think this is a qDSLRDashboard problem but I'm hopeful that someone can help me out. I can't get the OTG connection on my Samsung Galaxy S8 to work. I have tried the included OTG adapter and an aftermarket OTG cable. I have enabled "Developer Options" and tried all of the USB connection types but none works. When I connect the OTG cable I can see the light flash on my camera (Nikon D810) but the "Use USB for" option is always set to "Charge Connected Device". I try to check the radio box for "File Transfer" or "Photo Transfer" or any other option but the option selector dialog box just goes away. And when I open it back up it's set back to "Charge Connected Device". So I think my problem is that I can't change the USB connection type.
Has anyone successfully set up a Galaxy S8 to work with this app? If so, did you have to change some settings to make the OTG connection work?
Thanks in advance,
rgames
Thanks in advance,
rgames
