ILC-A68
Posted: 10 May 2019, 07:39
by Sengoku
Hello, I have a problem.
I’ve tried to connect qdd to my a68, but no results. Downloaded winusb driver, step-by-step installation. With this my Imaging Edge doesn’t recognise camera, but qdd does( if driver is not installed, then qdd stays on searchin...).
But even if installed and connected, the only step I see is Searching...
Connecting to DSLR ilc-a68
And nothing more. I’m trying to connect via usb, because a68 doesn’t have wifi module. After installation, in device mgr creates another „USB device” branch, with ilc-a68( not where all USB devices are listed). In driver details I see three drivers( one stored in sys32/drivers/winusb.sys. Second is the replaced driver from link, and third is something from windows as well.
Any ideas?
Re: ILC-A68
Posted: 10 May 2019, 09:05
Only the Sony mirrorless models are supported with the built in wireless and using the 'Smart remote control' camera application.
Sony cameras will not work with USB connection with qDslrDashboard.
Re: ILC-A68
Posted: 10 May 2019, 09:39
by Sengoku
Ok. Thank you. Another thing for moving on to E mount. I was afraid of my lenses, but now I know that they can be attached through adapter.
