Connecting D800 success with certified Nikon USB3
Posted: 10 Jul 2019, 04:18
I was able to connect to my Nikon D800 to qDslDashboard. But not with ControlMyCamera. And then it all failed.
I was using a USB3 after market connector for my TP-Link WiFi. Then I simply changed to the stock (thicker) Nikon certified USB3 connector for my TP-Link WiFi and it suddenly worked perfectly.
A simple fix. So many times problems are isolated to one very simply fix. And that was it. Use the certified connector.
Good luck.
Good luck.
