Page 1 of 2
Install Issue(s)
Posted: 12 Jul 2019, 02:11
by AndyPost
Hey Thrill Seekers,
Trying to install on Windows 7-64 bit.
If I try to install vcredist_x64.exe as I understand I must, I get a failed intall telling me another version of this product is already installed. Well there are many versions of Visual C++ installed, but none that match what it's trying to install.
If I try to jump right to qDslrDashboard.exe I get an error that api-ms-win-core-winrt-l11-0.dll is missing. Like I'll ever find that.
Any idea how to get it to install?
Re: Install Issue(s)
Posted: 12 Jul 2019, 07:06
Here is an archive with the missing dlls for the WIndows 7: https://drive.google.com/file/d/1WGyrGm ... sp=sharing
Please extract these files into the qDslrDashboard folder.
Posted: 25 Jul 2019, 16:38
by lokatz
I just ran into the same problem but the link to the DLLs has expired. Any chance you could make them available permanently somewhere? Thanks in advance.
Posted: 25 Jul 2019, 16:42
lokatz wrote: 25 Jul 2019, 16:38 I just ran into the same problem but the link to the DLLs has expired. Any chance you could make them available permanently somewhere? Thanks in advance.
Still works here.
Posted: 16 Nov 2019, 11:58
by ringo-san
I have the same problem as "AndyPost".
-> Installation of qdslrdashboard on Windows 7-64bit.
Visual C** (vcredist_x64.exe) is installed. However, when qDslrDashboard.exe is started, the "api-ms-win-core-winrt-l11-0.dll is missing" error appears.
The link to the DLLs has been expired.
Can anyone help?
Thanks in advance.
Posted: 16 Nov 2019, 16:26
Posted: 13 Apr 2020, 16:02
by zom
hubaiz wrote: 16 Nov 2019, 16:26 Here is a newer Windows build: https://drive.google.com/file/d/1hMHE8d ... sp=sharing
I am a Windows 10 user and had the same reported C++ problems when I tried to install. I just downloaded the files at the Google Drive destination pointed to in the post from hubaiz and the installation worked fine.
Thank you for your effort hubaiz.
Posted: 02 Jan 2021, 22:12
by richardarowe
Hi. So I am trying to run qDslrDashboard on a Windows 7(64) system and I run into the same issue as AndyPost; that the api-ms-win-core-winrt-l1-1-0.dll is missing. I have tried everything I can think of including downloading the x64 and x86 redistributables from Microsoft. All the links in this post have expired or do not point to a valid endpoint. Any help you can offer will be greatly appreciated. Rick
Posted: 04 Jan 2021, 07:50
Use the build from the previous post, that already has that dll included in the zip file.
Posted: 06 Jan 2021, 09:15
by samantha1
hallo
page not found
