Doesn't Work On Debian
The qDSLRDashboard programme doesn't work on Debian unstable, as there are several hard-linked libraries: libavcodec, libavformat, libavutils and libswscale. None of the absolute requirements are in the Debian repositories, so I can't even down-grade to make the programme work. Would not soft-linking be more useful?
Re: Doesn't Work On Debian
Delete the opencv libraries from the Qt_Libraries folder and use the system provided one or if that does not work then build yourself the opencv libraries.
That solved the matter for Ubuntu Vivid. This program needs a PPA as gphoto2 will not tether Nikon D3200 and dslrDashboard is just sweet.
