I saw that ddserver should run also an a 3020 TPlink router.
I install Openwrt on the 3020 router,
then I tried to use the ddserver package updater to install ddserver,
I didn't succeed.
I am wondering if it's the right batch, because it seems that the batch starts to remove existing ddserver
so any idea about how to install a ddserver on a 3020 tplink router
Thank you for any help
Dominique
how to install ddserver on a 3020 tplink router ?
Re: how to install ddserver on a 3020 tplink router ?
I am still trying...
I copied with winscp tje ipk file to the /tmp directory.
Then I launch the opkg install command with the ipk file
unfortunately I got an error : "/var/lock/opkg.lock No such file or directory.
It seems that it is a known bug within openwrt? , how to have a workaround ?
any other idea ?
Dominique
any other idea ?
Dominique
Sorry, seams I missed your post.
I already have OpenWrt for MR3020 here with ddserver included:
factory: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
sysupgrade: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Thank you very much, I succeeded to have my 3020 running.
I am able to have DSLRdashboard discovering and managing DSLR connected with USB
The next step where I dont succeed so far is to discover DSLR with the 3020 connected to my first 3040.
( the goal being to have one dslr connected on each one of the both routers.
so on each one separatly, it's OK
I configured the 3020 following the procedure you provided here :
when I long pressed the network button for 192.168.3.1 as IP I am not able to discovered the dslr
When I connect this dslr to the 3040 I discovered it with long press to 192.168.1.1
using the network disagnostic feature, I am able to ping each one from each other.
Any Idea about what is wrong in my configuration ?
I also tride to change to 192.168.2.1 the 3040 / same results.
I use DSLRdashboard 2.04, but I tride with 2.06 / same results
Thank you very much
Dominique
Thank you very much
Dominique
Probably you are missing some step from the instructions for multiple routers.
Did you add the manual route to the AP device?
Yes, probably I missed something...
I tried to check many times
Yes I add the static route as described page 10 of your detailled instruction.
may I attached some screenshots ?
Here are the screenshots of the both configurations
Thank you to have a look
maybe it's not normal to have a question mark for the 3020 associated station IP ( first screenshot )
Best regards
Dominique
Best regards
Dominique
- 3040-wireless-overview.jpg (32.65 KiB) Viewed 121648 times
- 3040-static route.jpg (14.04 KiB) Viewed 121648 times
- 3040-lan-interface.jpg (26.16 KiB) Viewed 121648 times
Also the 3020 screenshots about interfaces
- 3020-wan-interface.jpg (58.68 KiB) Viewed 121648 times
- 3020-lan-interface.jpg (56.21 KiB) Viewed 121648 times
- 3020-interfaces.jpg (41.2 KiB) Viewed 121648 times
last screenshots about the 3020 ( firewall and Wifi )
Thank you very much
Dominique
Thank you very much
Dominique
- 3020-wireless-overview.jpg (29.48 KiB) Viewed 121648 times
- 3020-wireless-network.jpg (79.84 KiB) Viewed 121648 times
- 3020-firewall.jpg (67.73 KiB) Viewed 121648 times
When you connect your PC wireless with the AP wireless
- can you access the http://192.168.2.1 from your web browser
- can you access the http://192.168.3.1 from your web browser
in qDD if you long press the 'Network' button and enter 192.168.3.1 and then connect can you access the connected camera?
