D5300 Nikon Wi-Fi no longer enabled
RAD
Post by RAD »
My D5300 turns off the Wi-Fi, at the source in the camera, every time the record video button is pushed.
Any Ideas?
No problem with the shutter or other controls.
Re: D5300 Nikon Wi-Fi no longer enabled
Yeah... Read camera manual. In there you have written that this will happen.
RAD
Post by RAD »
Then this program will not work to use an iPad mini as a monitor? Is there a way to treather it and use something like a hmdi lightening jack with this app?
RAD
Post by RAD »
Would a WU-1A wireless Nikon adaptor bypass the internal wi-fi and let the app run the video due to external wi-f?
With camera connected with USB (no matter if it is WU-1, wifi router or just cable) you can record video.
