I'm new to the qDslrDashboard using the TP-Link. Is there a way to get the Dashboard & the TP-link to work with an Internet network. (a home wifi network) so that post can be made straight from the dashboard to sites like Facebook?
Thank you,
Joe
Internet through the qDslrDashboard
Re: Internet through the qDslrDashboard
Yes it can be done but there are bunch of problems and downsides with it:
1. you have to correctly configure wireless and wired interfaces on router (I couldn't figure it out)
2. if router won't connect with default network the only way to fix it is with cable (ethernet) connection.
3. router cannot work as access point and wireless client simultaneously so the only AP will be your home network.
Thanks for the reply GonzoG. I "play" around with it. Thanks.
MacMac
MacMac
