Nikon D3100 Support
Posted: 23 Feb 2015, 23:04
by sheng
Hey there, not that much going on here yet, huh?
I used the no longer supported Android app with my Nikon D3100. Worked great (only storing images on Tablet SD card didn't work). Well, I got the new app today and...nothing works. It recognizes my Cam via USB with an Samsung Tab S. But I can't capture and the app does not display any capture.
greetz
sheng
Re: Nikon D3100 Support
Posted: 24 Feb 2015, 16:41
Will check however the D3100 is a budget model without a documentation for developers from Nikon and with a very limited set of PTP commands.
Posted: 04 May 2015, 10:46
by Poldinho19
Hi there,
any new infos?
Bought the necessary cables today and it doesn`t work.
Cheers
Fabian
P.S. I got a Sony Xperia Z3
Posted: 04 May 2015, 11:58
You only need an USB OTG adapter for your Android device.
As I wrote in the previous post D3100 will work but it is limited as it is a budget model.
Posted: 04 May 2015, 17:07
by Poldinho19
I have that Adapter.
What do you mein with "Limited"
My Xperia doesn't find anything via USB.
Posted: 04 May 2015, 17:31
It is a budget model with no documentation from Nikon and only with a limited set of PTP commands.
No live view, no movie recording, no BULB.
Does not support the event command so there is no property change notification.
Posted: 04 May 2015, 17:40
by Poldinho19
I Connect my Phone via Micro USB to the Mini USB Slot on the D3100 but nothing happens.
May i have bought a wrong cable?
Or is there anything i have to change on Phone or camera
Posted: 04 May 2015, 18:26
You need an USB OTG adapter, not just a micro USB to USB cable.
Posted: 04 May 2015, 18:29
by Poldinho19
Thats what i got.
Micro to usb and then the usb to Mini USB Otg Adapter.
Posted: 05 May 2015, 14:32
by GonzoG
You have wrong USB-OTG adapter.
As Hubaiz wrote - you need USB-OTG adapter for your phone. Than you connect adapter to phone, and camera to adapter.
