TP-Link 3040 Ver 2.5 - Not working
Posted: 10 Feb 2017, 16:40
by Vilhelm
I received my 3040 yesterday. Checked the HW version on the back to see it is ver 2.5. Haven't seen a lot of reference to that particular model online. Proceeded to load up the v2 OpenWRT firmware. The device accepted it no problem. Under the setting>software tab it indicates it is running DDSERVER 2.13. iphone and MacBook are able to connect to the DDServer network. I've connected my 5D (MKII & MKIII) to the 3040. Neither the OSX or IOS app is able to detect or pickup the camera. I've tried every possible combination of camera, cable, device, and order in which everything is connected or powered on. Is there a specific or alternate firmware I should be trying on this particular hardware version? The app opens no problem, but it's just a black screen with all the icons. I've tried the long press on the network button as well with no success.
Re: TP-Link 3040 Ver 2.5 - Not working
Posted: 11 Feb 2017, 07:50
For the MR3040 you need to use the 'Network' button (on iOS first button from left, on OSX second)
Did you try to long press the 'Network' button and in the upcoming IP dialog enter 192.168.1.1 and press the 'Ok' button? Does that connect?
Posted: 11 Feb 2017, 13:39
by Vilhelm
The long press method does not connect.
I tried on my old 40D, and everything seems to work as expected. There's something in this setup that is not working with the 5D MKII or the 5D MKIII. They both work with the software on the MacBook when directly connected via USB though.
Posted: 11 Feb 2017, 14:12
You need to connect it to the MR3040 full USB port, but if you get 40D working I guess you used it already.
If your 40D is working then the 5D Mk 2 and 3 will to, as same code is used.
Eventually try another USB cable, maybe a shorter one.
You can check the MR3040 system log, like this:
- turn on the MR3040 and wait till the wireless led is on
- connect your controlling device wireless to the MR3040 wireless
- connect your DSLR with USB cable to the MR3040 and turn it on
- open a web browser on your controlling device and navigate to
http://192.168.1.1
- navigate to the Status->System log (scroll to the end)
- you should have something like this at the end:
Feb 11 15:11:42 Arduino kern.info kernel: [243307.860000] usb 1-1.1.3: new high-speed USB device number 16 using ehci-platform
Feb 11 15:11:42 Arduino kern.info kernel: [243308.050000] usb 1-1.1.3: New USB device found, idVendor=04a9, idProduct=3253
Feb 11 15:11:42 Arduino kern.info kernel: [243308.050000] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Feb 11 15:11:42 Arduino kern.info kernel: [243308.050000] usb 1-1.1.3: Product: Canon Digital Camera
Feb 11 15:11:42 Arduino kern.info kernel: [243308.060000] usb 1-1.1.3: Manufacturer: Canon Inc.
Posted: 11 Feb 2017, 19:57
by Vilhelm
This is what appears at the end of my log after after trying the 40D (successfully) then the 5D MKII
Sep 8 11:56:56 OpenWrt user.info syslog: Incoming client connection
Sep 8 11:56:56 OpenWrt user.info syslog: Awaiting client connection
Sep 8 11:56:56 OpenWrt user.info syslog: USB Devices in
Sep 8 11:56:56 OpenWrt user.info syslog: Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Sep 8 11:56:56 OpenWrt user.info syslog: Number of alternate settings:
Sep 8 11:56:56 OpenWrt user.info syslog: Interface class: 9 Interface number: 0 Number of endpoints: 1
Sep 8 11:56:56 OpenWrt user.info syslog: Number of possible configurations: 1 Device Class: 0 VendorID: 1193, ProductID: 12614
Sep 8 11:56:56 OpenWrt user.info syslog: Interface class: 6 Interface number: 0 Number of endpoints: 3
Sep 8 11:56:56 OpenWrt user.info syslog: Found USB imaging device, get vendor and product
Sep 8 11:56:56 OpenWrt user.info syslog: Device Manufacturer: Canon Inc.
Sep 8 11:56:56 OpenWrt user.info syslog: Device Product: Canon Digital Camera
Sep 8 11:56:56 OpenWrt user.info syslog: Imaging USB devices found: 1
Sep 8 11:56:56 OpenWrt user.err syslog: Error reading total packet size: 0
Sep 8 11:56:56 OpenWrt user.err syslog: Stoping client
Sep 8 11:56:56 OpenWrt user.info syslog: Checking device with vendorId: 04a9 and productId: 3146
Sep 8 11:56:56 OpenWrt user.info syslog: Trying to open device
Sep 8 11:56:56 OpenWrt user.info syslog: Device open success
Sep 8 11:56:56 OpenWrt user.info syslog: USB device opened
Sep 8 11:56:56 OpenWrt user.info syslog: Read endpoint adress: 129
Sep 8 11:56:56 OpenWrt user.info syslog: Write endpoint adress: 2
Sep 8 11:56:56 OpenWrt user.info syslog: USB interface claimed
Sep 8 11:56:56 OpenWrt user.info syslog: vendor: 1193 product: 12614
Sep 8 11:56:56 OpenWrt user.info syslog: vendor: 43268 product: 17969
Sep 8 11:56:58 OpenWrt user.info syslog: Closing USB device
Sep 8 11:57:13 OpenWrt user.err syslog: Error reading total packet size: -1
Sep 8 11:57:13 OpenWrt user.err syslog: Stoping client
Sep 8 11:57:15 OpenWrt user.info syslog: Closing USB device
Sep 8 11:57:15 OpenWrt user.info syslog: USB interface released
Sep 8 11:58:29 OpenWrt kern.info kernel: [ 877.750000] usb 1-1: USB disconnect, device number 22
Sep 8 11:58:35 OpenWrt kern.info kernel: [ 883.710000] usb 1-1: new full-speed USB device number 23 using ehci-platform
Sep 8 11:58:36 OpenWrt kern.err kernel: [ 883.930000] usb 1-1: device descriptor read/64, error -71
Sep 8 11:58:36 OpenWrt kern.err kernel: [ 884.250000] usb 1-1: device descriptor read/64, error -71
Sep 8 11:58:36 OpenWrt kern.info kernel: [ 884.480000] usb 1-1: new full-speed USB device number 24 using ehci-platform
Sep 8 11:58:36 OpenWrt kern.err kernel: [ 884.700000] usb 1-1: device descriptor read/64, error -71
Sep 8 11:58:37 OpenWrt kern.err kernel: [ 885.020000] usb 1-1: device descriptor read/64, error -71
Sep 8 11:58:37 OpenWrt kern.info kernel: [ 885.250000] usb 1-1: new full-speed USB device number 25 using ehci-platform
Sep 8 11:58:37 OpenWrt kern.err kernel: [ 885.730000] usb 1-1: device not accepting address 25, error -71
Sep 8 11:58:38 OpenWrt kern.info kernel: [ 885.850000] usb 1-1: new full-speed USB device number 26 using ehci-platform
Sep 8 11:58:38 OpenWrt kern.err kernel: [ 886.330000] usb 1-1: device not accepting address 26, error -71
Sep 8 11:58:38 OpenWrt kern.err kernel: [ 886.330000] hub 1-0:1.0: unable to enumerate USB device on port 1
Sep 8 11:59:07 OpenWrt user.info syslog: Incoming client connection
Sep 8 11:59:07 OpenWrt user.info syslog: Awaiting client connection
Sep 8 11:59:07 OpenWrt user.info syslog: USB Devices in
Sep 8 11:59:07 OpenWrt user.info syslog: Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Sep 8 11:59:07 OpenWrt user.info syslog: Number of alternate settings:
Sep 8 11:59:07 OpenWrt user.info syslog: Interface class: 9 Interface number: 0 Number of endpoints: 1
Sep 8 11:59:07 OpenWrt user.info syslog: Imaging USB devices found: 0
Sep 8 11:59:07 OpenWrt user.err syslog: Error reading total packet size: 0
Sep 8 11:59:07 OpenWrt user.err syslog: Stoping client
Sep 8 11:59:09 OpenWrt user.info syslog: Closing USB device
Posted: 13 Feb 2017, 20:21
Seams there is some problem with USB.
Can you try another USB cable ?
Posted: 25 Feb 2017, 04:55
by Vilhelm
I've tried about 10 different USB cables. Like I said, it seems to work fine straight USB to the Mac, so I can't imagine it has anything to do with my cables or ports (especially on 2 seperate 5D's). Are there specific camera settings I should be looking at? There doesn't seem to be anything in the documentation on setup on the camera side.
Posted: 25 Feb 2017, 08:10
No need for any special camera settings.
You can try to flash the sysupgrade image again.
You can follow the upgrade instructions:
http://dslrdashboard.info/tp-link-mr304 ... e-upgrade/
Posted: 19 Nov 2017, 12:26
by marz71
hi Vilhelm
This is very confusing. I have the same problem. It seems like this is a complex problem with several factors involved. I don't think it's related to ddserver. I also have problem with the same router and canon 550/t2i. My nikon cameras work just fine. My canon shows message busy when I connect to usb port of router and camera freezes. If you search the dslrdashboard forum you only find diffuse answers like: have you tried another cable? Is your cable broken? Have you tried restart? Have you tried upgrading? Clearly answers from people who have not experienced the problem.
Check the status->system log or ssh to router and do:
logread -f
while you plug in/unplug.
The most confusing part is that from time to time it works. I still have not found a safe method to make it work but this helps:
- insert a passive usb2.0 hub between the router and camera
- use long cable (mine is about 3m long).
- when restarting the router, do a hard reboot by turning power off/on.
I found some hints in openwrt forums. Several people are reporting this kind of errors:
[ 3537.660000] usb 1-1: device not accepting address 5, error -71
[ 3537.660000] usb usb1-port1: unable to enumerate USB device
Several people have reported problems with connecting usb-sticks or usb-harddrives. However the devices are working fine with original firmware, so it must be related to linux distribution. This problem has been ongoing for several years. It looks to me like there is some bad combination of router hardware and canon usb chips. Maybe it's possible to tweek Linux distribution somehow? Looks like some kind of timing problem, since (in my case this moment) it's working fine with long usb cable.
I'm suprised that there is no more noise about this problem. Canon is very popular brand. Maybe there are several versions of the router hw and the problem is fixed in later versions?
