AF cannot be changed
Posted: 22 Apr 2015, 18:18
by rsync
I cannot change the AutoFocus point on my iPad. Connected is a Canon APS-C camera and everything work other then the change of the focus point.
Any settings required ?? I have version V0.2.7 on iPad with IOS 8.3
Re: AF cannot be changed
Posted: 23 Apr 2015, 13:25
What is your camera model?
Posted: 23 Apr 2015, 22:08
by rsync
I have a Canon 7D
Posted: 24 Apr 2015, 18:49
by rsync
Fixed, it is a setup of the Camera which then allows the move of the AF frame
Posted: 28 Apr 2015, 12:41
by Jon
rsync - could you post the Canon setting you found needed to be changed in case others see the same, or similar, problems
Posted: 03 May 2015, 18:24
by lcheung123
I encountered similar problem, and had the AF point (movable box) missing using 100mm IS macro lens. I then changed to 70-200 IS II and it appears, I switched back to 100mm it appears magically.
