Raspberry Pi 2 Installation guide [Closed]
Posted: 28 Aug 2017, 09:38
by PiKmera
Hi Everybody,
I'm trying to install the server in a Rpi B2, even following the instructions here or in the Github, there's not any way it runs there. I'm sure I'm making something wrong.
1st method:
1. Flash latest Raspbian ISO from Rpi websited into a SD card
2. Run sudo apt-get update && apt-get upgrade
3. Reboot
4. Download and unzip the file (In /home/pi/Downloads/) downloaded from https://dslrdashboard.info/download/ras ... pi-v3-5-3/
5. Run sudo apt-get update && apt-get upgrade
6. Reboot
7. Enter to the folder /home/pi/Downloads/qDslrDashboard_V3.5.3_RPI/ and run sudo ./qDslrDashboard.sh
8. There's always a missing libraries..
2nd method:
3. Reboot
4. Run git clone git://github.com/hubaiz/DslrDashboardServer package/DslrDashboardServer
6. Reboot
7. Run sudo make menuconfig
8. Error message "no rule to make target 'menuconfig'"
I'm not sure if the problem might be in the memory assigned to the GPU, when I set it to 512, the Pi won't boot. Once I set it for any lower value, it boots normally. Even gpu_mem_1024=512 let me boot the Pi, however when check the memory it says 64M.
Any suggestion where I'm making the mistake in the procedure?
Thanks in advance!
Re: Raspberry Pi 2 Installation guide
Posted: 28 Aug 2017, 11:40
Please check my answer here: viewtopic.php?f=5&t=1433&start=20#p6370
Posted: 28 Aug 2017, 11:50
by PiKmera
Thanks, I close this topic then.
