Two Android Phones Connection?
Posted: 15 Sep 2019, 08:46
After no luck trying to get my 3040 working I am trying to connect via the Canon WiFi option, I have two Android options Large Pad and Smaller phone, I use the Pad inside and the Phone when outside but how can I get both options to connect under the same WiFi code, not useing both at the same time obviously.
I only seem to be able to connect if I make two log on option numbers in the camera. Thankyou. Russ.
