No function on Record button
Posted: 02 Jun 2015, 20:30
Zoltan,
thank you for the great piece of software! There is huge potential in it.
My environment:
- Nikon D7200, brand new
- USB cable (also tried the built-in WiFi, but learned that it does not allow video due to camera restrictions but takes stills nicely)
- Nexus 7, Android version 5.1
All I have tried up till now has worked with USB except video recording. I can shoot stills with or without Lv screen, I can refocus,
I can see in Lv screen the voice levels, I can view stills, change parameters etc.
But I can't trigger the video recording on. There is the button with a Video Camera icon, it is looking the same as others
but if I press there is no action. There is also another button "LV REC" and if I press that one it turns red but no video appears
on the memory card either then. If I have the LV video switch locked on the camera body then the Video Camera button is with borders.
If I have LV Camera mode locked on the camera body there are no borders on the Video Camera button. If I remove the USB cable
from the camera body and then press Lv and camera video button voila, it records. So the Dslrdashboard seems to know
when it can record, camera seems to be ready for record, but no recording takes place.
- Martti
My environment:
- Martti
