OSX with Sony A6000 Custom bracketing
cateye999
Post by cateye999 »
I'm currently using Mac Sierra with qDD OSX V3.5.3 x64 version running wifi controlling with Sony A6000.
There are few problem for controlling the camera,
1.Custom bracketing:
The number of pictures for counting works but EV step not.
I set count 2 for under and over exp. then I got 5 identical pictures instead of EV changing.
2.Camera Control on bottom screen:
I can see the changes of ISO,fNumber,Shutter that I tweaked from camera instantly
and I can also enter the selection menu for each of them while camera is on M mode.
But after I select the value I want, ex. ISO, the setting just switch back to camera setting.
It seems the camera setting is still overriding the qDD control.
So I'm wondering if those problems happen only on Sony camera or on Mac OS
and would Custom bracketing works normally on iOS with Sony A6000 too.
Thank you.
