Infinity setting
Posted: 04 Jul 2018, 19:53
I am intrested in astrophotography. One problem some astrophotograhers have is to find the right focus point. Stars are not as bright in the view finder as you might think. A solution to this problem could look like this:
The You take pictures of the bright moon which is easy to focus with qdslrdashboard. The focus distance to the moon is the same as the focus distance to the stars. Now you store the settings. Some nights later - the moon is not shining and its pretty dark - you just hit a button and your lens is set to the right focus distance. It would be great if there would be a way to store infinity settings for different lenses.
