qDSLRdashboard can not connect with TP-Link 3040
Posted: 20 Sep 2017, 14:22
Hello Users
I have a big trouble with the Software qDSLRdashboard and the TP-Link 3040
I have install the Software and Firmware of the TP-LINK 3040 Router.
When i connected the Router with my iPad or iMac, i have not Problems.
When i started the App qDSLRdashboard and click on connection, i become the following information
Under the ip 192.168.1.1 i can log in and can see all of settings.
i can connect over WLan withe the Computer or iPad with the Router, but than....
Searching for DDServer
DDServer not found, connecting to IP: 192.168.1.1
List connected DSLR at IP 192.168.1.1
Error gettingDSLR list from IP: 192.168.1.1
What is the Problem?
Can you help me?
Hardware:
TP-LINK Portable 3G/4G Wireless N Router TL-MR3040
iPad Pro 4G / Cellular with qDSLRdashboard App
iMac 27“ with the Software qDSLRdashboard
Canon EOS 1200D
The Post "Checking the ddserver installation and USB connection" i have did it.
i did Firmware Update TP-LINK 3040MR
I did Firmware Update Camera
and now i have no idea what can i do at next
Here the System Log
Sep 8 18:12:04 OpenWrt syslog.info syslogd started: BusyBox v1.19.4
Sep 8 18:12:04 OpenWrt kern.notice kernel: klogd started: BusyBox v1.19.4 (2014-07-11 18:33:29 CEST)
Sep 8 18:12:04 OpenWrt kern.notice kernel: [ 0.000000] Linux version 3.3.8 (hubaiz@xandroid64) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Jul 11 18:39:12 CEST 2014
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] MyLoader: sysp=fa89c804, boardp=69cd3b24, parts=31a09c82
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] SoC: Atheros AR9330 rev 1
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Determined physical RAM map:
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] memory: 02000000 @ 00000000 (usable)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Zone PFN ranges:
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Normal 0x00000000 -> 0x00002000
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Movable zone start PFN for each node
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Early memory PFN ranges
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] 0: 0x00000000 -> 0x00002000
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] On node 0 totalpages: 8192
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 802d61e0, node_mem_map 81000000
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] Normal zone: 64 pages used for memmap
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] Normal zone: 8128 pages, LIFO batch:0
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Sep 8 18:12:04 OpenWrt kern.notice kernel: [ 0.000000] Kernel command line: board=TL-MR3040 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Sep 8 18:12:04 OpenWrt kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Memory: 29116k/32768k available (2115k kernel code, 3652k reserved, 406k data, 208k init, 0k highmem)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] NR_IRQS:51
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-MR3040
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.350000] bio: create slab <bio-0> at 0
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.360000] Switching to clocksource MIPS
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.360000] NET: Registered protocol family 2
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.370000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.370000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.370000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.380000] TCP: Hash tables configured (established 1024 bind 1024)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.390000] TCP reno registered
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 0.400000] NET: Registered protocol family 1
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ath: country maps to regdmn code: 0x3a
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ath: Country alpha2 being used: US
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ath: Regpair used: 0x3a
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.450000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Sep 8 18:12:04 OpenWrt kern.debug kernel: [ 9.460000] Registered led device: ath9k-phy0
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.460000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.470000] cfg80211: Calling CRDA for country: US
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.470000] cfg80211: Regulatory domain changed to country: US
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.470000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.480000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.490000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.500000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.510000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.510000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.520000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.570000] PPP generic driver version 2.4.2
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 9.820000] ip_tables: (C) 2000-2006 Netfilter Core Team
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.040000] NET: Registered protocol family 24
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.060000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.070000] ehci-platform ehci-platform: Generic Platform EHCI Controller
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.070000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.110000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.130000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.130000] hub 1-0:1.0: USB hub found
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.130000] hub 1-0:1.0: 1 port detected
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.160000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
Sep 8 18:12:04 OpenWrt kern.info kernel: [ 10.400000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Sep 8 18:12:06 OpenWrt daemon.notice netifd: Interface 'lan' is now up
Sep 8 18:12:06 OpenWrt kern.info kernel: [ 14.830000] device eth0 entered promiscuous mode
Sep 8 18:12:06 OpenWrt daemon.notice netifd: Interface 'loopback' is now up
Sep 8 18:12:07 OpenWrt user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.070000] cfg80211: Calling CRDA for country: DE
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.070000] cfg80211: Regulatory domain changed to country: DE
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.070000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.080000] cfg80211: (2400000 KHz - 2483000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.090000] cfg80211: (5150000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.100000] cfg80211: (5250000 KHz - 5350000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Sep 8 18:12:11 OpenWrt kern.info kernel: [ 19.100000] cfg80211: (5470000 KHz - 5725000 KHz @ 40000 KHz), (N/A, 2700 mBm)
Sep 8 18:12:13 OpenWrt kern.info kernel: [ 21.150000] device wlan0 entered promiscuous mode
Sep 8 18:12:13 OpenWrt kern.info kernel: [ 21.200000] br-lan: port 2(wlan0) entered forwarding state
Sep 8 18:12:15 OpenWrt kern.info kernel: [ 23.200000] br-lan: port 2(wlan0) entered forwarding state
Sep 8 18:12:16 OpenWrt authpriv.info dropbear[879]: Running in background
Sep 8 18:12:16 OpenWrt authpriv.warn dropbear[881]: Failed listening on '22': Error listening: Address already in use
Sep 8 18:12:16 OpenWrt authpriv.info dropbear[881]: Premature exit: No listening ports available.
Sep 8 18:12:18 OpenWrt auth.err sshd[889]: error: Bind to port 22 on 0.0.0.0 failed: Address already in use.
Sep 8 18:12:18 OpenWrt auth.crit sshd[889]: fatal: Cannot bind any address.
Sep 8 18:12:19 OpenWrt user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Sep 8 18:12:19 OpenWrt user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: started, version 2.66 cachesize 150
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq-dhcp[947]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: using local addresses only for domain lan
Sep 8 18:12:23 OpenWrt daemon.warn dnsmasq[947]: no servers found in /tmp/resolv.conf.auto, will retry
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq[947]: read /etc/hosts - 1 addresses
Sep 8 18:12:23 OpenWrt daemon.info dnsmasq-dhcp[947]: read /etc/ethers - 0 addresses
Sep 8 18:12:23 OpenWrt user.info sysinit: setting up led USB
Sep 8 18:12:23 OpenWrt user.info sysinit: setting up led WLAN
Sep 8 18:12:23 OpenWrt user.info sysinit: setting up led LAN
Sep 8 18:12:23 OpenWrt user.info sysinit: Starting DslrDashboardServer (ddserver)
Sep 8 18:12:23 OpenWrt user.info sysinit: Saving PID 963 to /var/run/ddserver.pid
Sep 8 18:12:23 OpenWrt user.info sysinit: DslrDashboard server started
Sep 8 18:12:23 OpenWrt user.info syslog: DslrDashboardServer starting
Sep 8 18:12:23 OpenWrt user.info syslog: Starting socket server on port 4757
Sep 8 18:12:23 OpenWrt user.info syslog: Awaiting client connection
Sep 8 18:12:23 OpenWrt user.info syslog: Starting UDP listener
Sep 8 18:12:23 OpenWrt user.info syslog: join multicast group: 224.1.2.3
Sep 8 18:12:23 OpenWrt user.err syslog: error in joining multicast group -1
Sep 8 18:12:35 OpenWrt kern.info kernel: [ 43.450000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sep 8 18:12:35 OpenWrt kern.info kernel: [ 43.700000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sep 8 18:12:36 OpenWrt kern.info kernel: [ 43.950000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Sep 8 18:12:36 OpenWrt kern.err kernel: [ 44.370000] usb 1-1: device not accepting address 4, error -71
Sep 8 18:12:36 OpenWrt kern.info kernel: [ 44.490000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Sep 8 18:12:37 OpenWrt kern.err kernel: [ 44.910000] usb 1-1: device not accepting address 5, error -71
Sep 8 18:12:37 OpenWrt kern.err kernel: [ 44.910000] hub 1-0:1.0: unable to enumerate USB device on port 1
Sep 8 18:12:49 OpenWrt daemon.info hostapd: wlan0: STA e4:ce:8f:64:4a:e5 IEEE 802.11: Station tried to associate before authentication (aid=-1 flags=0x0)
Sep 8 18:12:49 OpenWrt daemon.info hostapd: wlan0: STA e4:ce:8f:64:4a:e5 IEEE 802.11: authenticated
Sep 8 18:12:49 OpenWrt daemon.info hostapd: wlan0: STA e4:ce:8f:64:4a:e5 IEEE 802.11: associated (aid 1)
Sep 8 18:12:49 OpenWrt daemon.info dnsmasq-dhcp[947]: DHCPREQUEST(br-lan) 192.168.1.199 e4:ce:8f:64:4a:e5
Sep 8 18:12:49 OpenWrt daemon.info dnsmasq-dhcp[947]: DHCPACK(br-lan) 192.168.1.199 e4:ce:8f:64:4a:e5 Marios-iMac
Can you help me?
Hardware:
Canon EOS 1200D
Here the System Log
