No holy grail function with Sony A6300
Posted: 07 Jun 2018, 14:34
by smnmbs
I´m not able to use the holy grail function in the lrtimelapse module with the Sony A6300. It´s no problem to connect my tablet (Samsung Galaxy TabPRo 10.1 with lineageOS) with qDSLRDashboard, I can use the Liveview and all parameters can be changed via app. But when I change into the lrtimelapse module, there is no Liveview available anymore. I still can change the settings (ISO, …) via app and when I take a picture, the app recognizes that, but doesn´t display the picture (display next jpg is activated). And the Holy Grail button is not available at all. What´s the problem?
Thanks!
Edit: I just tried it with another Camera (Sony A6000) and it´s the same issue.
Re: No holy grail function with Sony A6300
Posted: 08 Jun 2018, 18:40
Be sure the camera is set to M mode.
There is no use of the live view in LrTimelapse module and it will work faster and you battery will last longer.
Posted: 09 Jun 2018, 07:38
by smnmbs
Thanks for your quick reply! I tried it in the M mode, but it´s the same problem. I can capture a photo, the frame counter works and the interval is calculated, but there is no jpg displayed and no holy grail function available. Any other ideas?
Posted: 09 Jun 2018, 16:27
Do you use the latest 'Smart remote control' version ( https://www.playmemoriescameraapps.com/ ... _00-F00002 )
Posted: 09 Jun 2018, 17:44
by smnmbs
Yes, I have the newest version of the remote control app. I tested a little bit today and it seems to be a device issue. With my Samsung Galaxy TabPro 10.1 with Lineage 13.1 I have the described problems. With my Xiaomi Redmi Note 4x with Lineage 14.1 I can hardly connect to your app and when it works the app crashes immediately when I start the lrtimelapse module. But with my Sony Xperia Z5 with lineage 14.1 it works perfectly incl. holy grail. How do I get the tablet (Galaxy TabPro 10.1) to run?
Posted: 11 Jun 2018, 13:03
I don't know what could be the problem on your TabPro. qDslrDashboard works same on Lineage 13.1 and 14.1 and also same on your Sony and Samsung device.
