qdslrd immediately quits . .
Posted: 10 Oct 2018, 00:33
by klausesser
. . after starting it.
Sometimes i prefer to use it tethered with my 7" Asus pad for focusstacking. For a long time it worked very well!
But since some weeks it doesn´t start at all - no matter it´s connected or not.
Error message comes immediately after start saying: "qdslr quits".
On my iPad Mini i use Wlan with a TPLink mini-router. No problems.
Also on iPhone it works well.
Just Android refuses to run it.
best regards, Klaus
Re: qdslrd immediately quits . .
Posted: 10 Oct 2018, 05:16
Had some reports regarding it and investigating. Will soon release an update.
Posted: 10 Oct 2018, 10:06
by dertoni
Hi there,
i had the same Problems yesterday after i updated my iPad Air 2 to iOS 12.0.1. qDslrDashboard immediately quits. I then tried to delete and reinstall it but now i can´t find qDslrDashboard in the appstore anymore? What happened and where can i find it?
On my iPhone 6 running iOS 12.0 it works perfectly fine.
Posted: 10 Oct 2018, 14:18
dertoni wrote: 10 Oct 2018, 10:06 Hi there,
Note that klausesser is referring to an Android device.
To install it again on the iOS follow the instructions in this page: https://support.apple.com/en-ca/HT201272
Posted: 10 Oct 2018, 15:44
by dertoni
Hi hubaiz,
oops! yeah sorry for that should have opened a new Thread.
Thanks for the Link, i did that but didn´t help. App immediately quits after opening. Could it be the 12.0.1 Update?
Posted: 10 Oct 2018, 16:23
dertoni wrote: 10 Oct 2018, 15:44 oops! yeah sorry for that should have opened a new Thread.
It could, I have 12 on my iPad Mini2 and it works as it should.
I'm preparing a new update but must wait for a new Qt version that supports the new build environment.
Posted: 10 Oct 2018, 17:34
@dertoni is any of the Accesibility settings enabled on your iOS device? If yes can you try and turn it off?
Posted: 18 Oct 2018, 09:33
by dertoni
@hubaiz Sorry for the late reply. Everything is/was turned off. Btw why is the app gone from the AppStore? Like i said on my phone with 12.0 it works just fine im pretty sure its because of 12.0.1 Update. Would be great if you find a solution anytime soon. Thanks a lot!
Posted: 26 Oct 2018, 12:25
by klausesser
hubaiz wrote: 10 Oct 2018, 05:16 Had some reports regarding it and investigating. Will soon release an update.
Thx!
best regards,
Klaus
