DslrDashboard stops working at some point, no errors
Re: DslrDashboard stops working at some point, no errors
1. BUlb will not work with D7000 as it does not have the required command for that (Nikon added that feature from D7100)
2. with a fast SD card 30sec shutter with 35sec interval should work. My D7100 has no problem with that. (Check if you maybe have NR enabled)
aaronpriest
Post by aaronpriest »
hubaiz wrote:1. BUlb will not work with D7000 as it does not have the required command for that (Nikon added that feature from D7100)
D700, not D7000. Long exposure noise reduction was not enabled. I shoot too many timelapses and panoramas to find it useful. I use dark frames and deal with it in post-production later.
Same with D700, BULB will not work. BULB is only available on newer Nikon models after D7100.
aaronpriest
Because there is no shutter cable I would assume? Bulb over USB alone is an issue on older models?
It is not an issue, it is not implemented by Nikon in older models. As I wrote Nikon begin adding the BULB option (command) with the D7100 model and the models after it.
I've testes D300s and there is no problem with 5 second gap between shots.
Camera set to RAW+JPEG basic small, CF Sandisk Extreme 60MB/s.
I think it is due to your camera settings or slow CF card that you need longer time.
And for startrails I don't use LRTimelapse at all. Just set correct exposure and use internal qDD interval (on cameras with BULB over USB) or 30s time in camera and plug shorted cable in release cable socket so camera does not have any gaps between photos.
aaronpriest
GonzoG wrote:I've testes D300s and there is no problem with 5 second gap between shots.
Interesting. I have a 64GB 90MB/sec Sandisk Extreme Pro. I can use an interval of 0.1 with a Promote Control without any dropped frames. It's not the camera. It might be the Wifi however. I'm going to buy an OTG cable and try wired, but lots of folks are saying it doesn't work on a Nexus 7 2013, only the older 2012. We'll see...
I was using LRTimelapse module for a dual purpose, both for exposure ramping for timelapse footage, and also to use some of the cobalt blue color in the sky at the tail end of nautical twilight for star trails. I do this often with a Promote Control, but my 12 year old shutter cable finally wore out on this trip and so I was stuck trying to find something else I could use for ramping. My Ramper Pro was driving my D810 on a Panoneed robotic head for a spherical timelapse.
aaronpriest
hubaiz wrote:It is not an issue, it is not implemented by Nikon in older models. As I wrote Nikon begin adding the BULB option (command) with the D7100 model and the models after it.
Without being a programmer, I guess I don't understand what command was added to later models. I use bulb all the time on the D700 and switch from manual to bulb mode via USB command (not having to touch the camera) with a Promote Control and Ramper Pro. But maybe you mean a different feature or programming code I'm not aware of, as those two devices use both a USB and dedicated shutter cable, not USB alone.
BULB capture will work with an external trigger on D700.
BULB capture can't be started from the application on the D700.
GonzoG wrote:Interesting. I have a 64GB 90MB/sec Sandisk Extreme Pro. I can use an interval of 0.1 with a Promote Control without any dropped frames.
It is not the same when you start a capture with an external trigger or when you start a capture from application with a PTP command.
You can use your external trigger with qDD and have 0.1 interval.
