Page 1 of 2
ControlMyCamera is not available in the App Store
Posted: 29 Sep 2019, 19:22
by lichtakrobat
Is the iOS App ControlMyCamera no longer available?
In the App Store I get an error message that the app is currently not available in this region.
Re: ControlMyCamera is not available in the App Store
Posted: 30 Sep 2019, 05:54
Unfortunately Apple removed the application due to a complaint.
I'm working on to bring it back.
Posted: 05 Oct 2019, 18:34
by ronwsmith
Any projection on how soon there will be a new release? I upgraded my phone (really pocket camera upgrade) and the operating system to iOS 13.1.2. ControlMyCamera appears to be no longer available on the App Store which means I'm dead in the water.
Posted: 22 Oct 2019, 11:18
by honkycat696
Any news on this? I bought all of the tech, was about to buy the app and it's not available. :(
Posted: 03 Nov 2019, 22:59
by tictac
Any update on this? I purchased the old app but it doesn't even show up in "My Purchases" so I can install it on my new device.
Posted: 06 Dec 2019, 15:07
by peris2312
Same here too,
I have bought this application at 26 July 2019 and before one mounth need to format my ipad and then to re-install it and i cannot download it.
Nobody inform us about the solution for this problem.
Where is the support of this app???
waiting a solution soon otherwise i need a refund.
Posted: 06 Dec 2019, 15:23
by peris2312
i am waiting 2 months now without results!
i need a solution soon otherwise refund please...
Posted: 07 Dec 2019, 07:48
by lichtakrobat
Are there any updates? When will the app be available again in the store?
Posted: 07 Dec 2019, 12:33
Unfortunately not yet.
If you purchased then you can use this guide to install it again: https://support.apple.com/en-ca/HT201272
If this does not work then you should contact Apple for a solution.
Posted: 31 Dec 2019, 15:13
by Hexe007
Unfortunately, the described workaround does not work either.
I wanted to reinstall the app to run the z6. As I did not know that there are serious issues with the app I was not able to install it again. :(
Is anyone going to fix this problem or do we need to look for another solution?
