AR750s bug with ddserver
Posted: 11 Jun 2021, 22:39
by dragonlost
Hello.
I have a gl.inet AR750s.
This router works on OpenWrt 19.07.7
I did not find a version of ddserver precompiled in version ath79.
So I compiled my own version with the gl.inet sdk.
I installed it and then launched it and no worries.
I plugged in my canon 500D then try to connect with qdslrdashbord 3.6.4 on Windows 10
The app sees the canon:
"connecting to DDServer DSLR Canon Inc. Canon Digital Camera"
But nothing is displayed and the application crashes after 30s/1min
So I'm looking for a solution to make ddserver work on my new router. ideas ?
on the first version of the AR750s the openWRT version allowed to install the version for ar71xx which worked correctly.
kernel log :
[ 5448.779479] usb 1-1: new high-speed USB device number 19 using ehci-platform
[ 5560.160547] do_page_fault(): sending SIGSEGV to ddserver for invalid write access to 00000000
[ 5560.169386] epc = 00401869 in ddserver[400000+4000]
[ 5560.174459] ra = 00401869 in ddserver[400000+4000]
system log :
Fri Jun 11 22:32:03 2021 kern.info kernel: [ 5448.779479] usb 1-1: new high-speed USB device number 19 using ehci-platform
Fri Jun 11 22:32:36 2021 user.info : DslrDashboardServer starting
Fri Jun 11 22:32:36 2021 user.info : Starting socket server on port 4757
Fri Jun 11 22:32:36 2021 user.info : Awaiting client connection
Fri Jun 11 22:32:36 2021 user.info : Starting UDP listener
Fri Jun 11 22:32:36 2021 user.info : join multicast group: 224.1.2.3
Fri Jun 11 22:32:55 2021 user.info : Incoming client connection
Fri Jun 11 22:32:55 2021 user.info : Awaiting client connection
Fri Jun 11 22:32:55 2021 user.info : USB Devices in
Fri Jun 11 22:32:55 2021 user.info : Number of possible configurations: 1 Device Class: 0 VendorID: 1507, ProductID: 1874
Fri Jun 11 22:32:55 2021 user.info : Number of alternate settings:
Fri Jun 11 22:32:55 2021 user.info : Interface class: 8 Interface number: 0 Number of endpoints: 2
Fri Jun 11 22:32:55 2021 user.info : Number of possible configurations: 1 Device Class: 0 VendorID: 1193, ProductID: 12751
Fri Jun 11 22:32:55 2021 user.info : Interface class: 6 Interface number: 0 Number of endpoints: 3
Fri Jun 11 22:32:55 2021 user.info : Found USB imaging device, get vendor and product
Fri Jun 11 22:32:55 2021 user.info : Device Manufacturer: Canon Inc.
Fri Jun 11 22:32:55 2021 user.info : Device Product: Canon Digital Camera
Fri Jun 11 22:32:55 2021 user.info : Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Fri Jun 11 22:32:55 2021 user.info : Interface class: 9 Interface number: 0 Number of endpoints: 1
Fri Jun 11 22:32:55 2021 user.info : Number of possible configurations: 1 Device Class: 9 VendorID: 1507, ProductID: 1560
Fri Jun 11 22:32:55 2021 user.info : Imaging USB devices found: 1
Fri Jun 11 22:32:55 2021 user.err : Error reading total packet size: 0
Fri Jun 11 22:32:55 2021 user.err : Stoping client
Fri Jun 11 22:32:55 2021 user.info : Checking device with vendorId: 04a9 and productId: 31cf
Fri Jun 11 22:32:55 2021 user.info : Trying to open device
Fri Jun 11 22:32:55 2021 user.info : Device open success
Fri Jun 11 22:32:55 2021 user.info : USB device opened
Fri Jun 11 22:32:55 2021 user.info : Read endpoint adress: 129 max pSize 512
Fri Jun 11 22:32:55 2021 user.info : Write endpoint adress: 2 max pSize 512
Fri Jun 11 22:32:55 2021 user.info : Interrupt endpoint address: 131 max pSize 8
Fri Jun 11 22:32:55 2021 user.info : USB interface claimed
Fri Jun 11 22:32:55 2021 user.info : vendor: 1193 product: 12751
Fri Jun 11 22:32:55 2021 user.info : vendor: 43268 product: 53041
Fri Jun 11 22:32:57 2021 user.info : Closing USB device
Fri Jun 11 22:33:55 2021 kern.info kernel: [ 5560.160547] do_page_fault(): sending SIGSEGV to ddserver for invalid write access to 00000000
Fri Jun 11 22:33:55 2021 kern.info kernel: [ 5560.169386] epc = 00401869 in ddserver[400000+4000]
Fri Jun 11 22:33:55 2021 kern.info kernel: [ 5560.174459] ra = 00401869 in ddserver[400000+4000]
