Bracketing setup (S4 + D90)
Posted: 28 May 2016, 10:39
That's a newbie question but can someone explain the difference between the Bracketing Mode and Custom Bracketing settings?
I am trying to shot (AE bracketing) a simple pattern -2ev -1ev 0 1ev 2ev. It works using Custom Bracketing but I can not make it works not using it. Without using it seems it just do something like -2ev -1ev 0 before going to -2ev?
I set the following settings In Bracketing Mode: [-]>0>[+] 1ev -2 1ev +2
(using Galaxy S4 + Nikon D90)
Maybe I did miss something completely?
Thanks!
Totally unrelated but the MacOS version of dslDashboard is crashing on my mac (10.8.5) due to opencv lib loading:
Process: qDslrDashboard [3037]
Path: /Applications/qDslrDashboard.app/Contents/MacOS/qDslrDashboard
Identifier: info.dslrdashboard.qDslrDashboard
Code Type: X86-64 (Native)
Parent Process: launchd [249]
Date/Time: 2016-05-28 12:28:31.386 +0200
OS Version: Mac OS X 10.8.5 (12F2560)
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
/Applications/qDslrDashboard.app/Contents/MacOS/../Frameworks/libopencv_imgproc.3.1.dylib
Dyld Error Message:
Symbol not found: ___sincos_stret
Referenced from: /Applications/qDslrDashboard.app/Contents/MacOS/../Frameworks/libopencv_imgproc.3.1.dylib
Expected in: /usr/lib/libSystem.B.dylib
Thanks!
Dyld Error Message:
