EOS Utility & dslrdashboard
Posted: 01 May 2017, 16:49
driver installed, and qdslrdashboard works fine...
BUT, can not use EOS Utility, and can not connect with Lightroom
Please advise how to change configuration (W10), manually if necessary, to allow for either driver to be used.
What service is enable/disable, or how to change windows, to allow for the choice of EOS Utility/Lightroom "or" qdslrdashboard.
I have followed the driver remover proceedure from this site, when the camera is plugged in, it puts the same driver back in. Therefore I am unable to switch to us BackyardEOS astrophotography app, or Lightroom, or EOS Utility (Canon).
I wish to switch/remove/reinstall between the two drivers.
