connecting Nikon D500...
WldWi11y
Re: connecting Nikon D500...
Post by WldWi11y »
Yes, the windows machine is hard wire connected to the wireless router on my network, and it does use that IP range. I'm not sure how I go about connecting the camera to it, or change the D500 IP. When I go to the WIFI setting on the camera settings it says it is Off. When I click "Establish Wi-Fi connection" I get a message that says "Connect to the following network from your smart device's Wi-Fi settings" and then shows the SSID and Password. After it sits on that message for a bit it says, "Unable to connect", and goes back the the "Establish Wi-Fi connection" menu.
Usually when I turn on anything with Wi-Fi it will show up on the network. This is not.
