has anyone used qDslrDashboard with a WT-7a?
Posted: 12 Mar 2018, 19:30
by frederic
Shortening a long story, I finally gave up some other things and now have a WT-7a attached to my D500.
Tentatively, it is great. It quickly and reliably pushes images to my tablet (surface pro 2017) with FTP, and the HTTP controls work well. Good range.
However, I of course want to use it with qDslrDashboard if only for focus stacking, and am unable to connect that way. I've tried (somewhat fancifully) connected to the FTP wireless setup and the HTTP wireless setup, then I went through the pairing process to create a Camera Control Pro connection. Fired that up, tried connecting with qDslrDashboard, no luck (although CCP does connect and control this way).
So before my remaining hair is torn out, has anyone done this successfully?
Re: has anyone used qDslrDashboard with a WT-7a?
Posted: 03 May 2019, 14:14
by frederic
Bump.
