Hi Zoltan,
Thanks for releasing ControlMyCamera for iOS, just purchased it!
Unfortunately the TP-Link MR304 router isn't available anymore. What are the recommended options? Thanks!
Best,
Andreas
TP-Link MR3040 not available anymore... Options?
Re: TP-Link MR3040 not available anymore... Options?
I have installed OpenWrt with ddserver on several TP-Link TL-WR902AC AC750 v.3.
The device has a good WiFi range (over 40 m in my experience, even more if you are in the US ).
If you are on Windows I recommend using Tftpd32 for the first install, because you can't install an OpenWrt image on the original firmware. It looks for a special signature, I guess. You have to do the first install via ftpd.
You can find a link to my how-to here.
