Hi folks,
I am wondering, it an OTG adaptor needed when the connection on both ends is USB C? My use-case is connecting a Nikon Z6 to a Samsung S9.
Will this work with just a standard USB-C to USB-C cable or is a host adaptor still needed?
If the adaptor is needed, can anyone link to one that is known to work? I can only find USB type A ones.
Thanks!
Is OTG adaptor needed for pure USB-C connection?
Re: Is OTG adaptor needed for pure USB-C connection?
Yes you need an OTG adapter for Android devices, it is not related to the connector.
Thanks. I wasn’t sure because I know the USB-C protocol allows for more intelligent host negotiation so devices can be both host and slave at the same time.
I cannot find any USB-C to USB-C OTG adaptors on the market. So do I get a USB-A to USB-C OTG adaptor then use a USB-A to USB-C cable on the other end?
That's the way I use it.
