Hi all.
I´m using Version 0.2.9 and maybe some can tell me how to start the Sky stacking function.
i´ve already set up some exposures but now i dont know how to start capture Pictures.
greetings
CyberMicha
Sky Stack
Re: Sky Stack
You just press shutter button.
Re: Sky Stack
One more Question.
Is there any way to controll my Focus with Dashboard without touching the lense?
Re: Sky Stack
Yes but only in LV. On bottom of screen you have buttons that move focus.
Re: Sky Stack
Ok found it. But only works if Auto Focus is enabled. so i have to disable it after focusing right?
Re: Sky Stack
How else it would work if youh need AF system to move lens focus....
And I don't know why you should disable AF. Just don't use it if not needed.
