Hello
I try to connect my d7100 to pc but it does not work
It is written "Connect to Nikon wireless camera at 192.168.1.2 (address is correct following TP-link status and nothing appends more.
Some help
Ethernet and Wi-fi
Ethernet and Wi-fi
Hello
I post an other message but I found the probleme but not the solution
The connecxion with WU-1A works goog while the ethernet cable is not connected to the pc
If connected, no communication with camera
But I need the ethernet, my picts are stored on a server
Re: Ethernet and Wi-fi
There might be a conflict with IP addresses.
What is your ehernet network IP config ??
