ControllMyCamera (1.0 iOS) crashes on Sony rx100V
Carl
Post by Carl »
Hi everybody,
After installing, the app usually works fine for a while but then crashes (so far only during user input, not when it was left to record a
Time lapse). After that, whenever a connection to the camera is established it crashes.
Is there a solution for this, I’ll go in a extended hike and I can’t re-download the app if it’s not working :cry:
I had qdslrdashboard which crashed too, so I switched to the newer app but it seems to have the same problem.
Thank you in advance!
Carl
Re: ControllMyCamera (1.0 iOS) crashes on Sony rx100V
Next version will fix this, it is a problem with Sony cameras.
Carl
Post by Carl »
Perfect,
thanks a lot for the quick answer! Do you know when that’ll be (approximately)?
Carl
Post by Carl »
Hey,
Just wanted to say thanks for the quick fix!
