ControlMyCamera is not available in the App Store
lichtakrobat
Post by lichtakrobat »
Is the iOS App ControlMyCamera no longer available?
In the App Store I get an error message that the app is currently not available in this region.
Re: ControlMyCamera is not available in the App Store
Unfortunately Apple removed the application due to a complaint.
I'm working on to bring it back.
ronwsmith
Post by ronwsmith »
Any projection on how soon there will be a new release? I upgraded my phone (really pocket camera upgrade) and the operating system to iOS 13.1.2. ControlMyCamera appears to be no longer available on the App Store which means I'm dead in the water.
honkycat696
Post by honkycat696 »
Any news on this? I bought all of the tech, was about to buy the app and it's not available. :(
tictac
Post by tictac »
Any update on this? I purchased the old app but it doesn't even show up in "My Purchases" so I can install it on my new device.
peris2312
Post by peris2312 »
Same here too,
I have bought this application at 26 July 2019 and before one mounth need to format my ipad and then to re-install it and i cannot download it.
Nobody inform us about the solution for this problem.
Where is the support of this app???
waiting a solution soon otherwise i need a refund.
peris2312
Post by peris2312 »
i am waiting 2 months now without results!
i need a solution soon otherwise refund please...
lichtakrobat
Are there any updates? When will the app be available again in the store?
Unfortunately not yet.
If you purchased then you can use this guide to install it again: https://support.apple.com/en-ca/HT201272
If this does not work then you should contact Apple for a solution.
Hexe007
Post by Hexe007 »
Unfortunately, the described workaround does not work either.
I wanted to reinstall the app to run the z6. As I did not know that there are serious issues with the app I was not able to install it again. :(
Is anyone going to fix this problem or do we need to look for another solution?
