Page 1 of 2
Control through Nikon's built-in WiFi
Posted: 31 Mar 2015, 21:21
by xingr8
Hi Zoltan,
Would it be possible to allow qDSLR to control the newer Nikons that have built-in WiFi through their built-in link? This would save having to buy and maintain a TP-LINK TL-MR3040 or WU-1. One less battery to plug in every night and piece of gear to lug around.
I have just received my new Nikon D7200 and am looking forward to an update that will support it. Thanks for the good work.
xingr8
Re: Control through Nikon's built-in WiFi
Posted: 01 Apr 2015, 05:10
This function is available from start with the 'Nikon wireless' button
Posted: 01 Apr 2015, 10:30
by Marckov85
Dear Zoltan,
Any chance i can get the open source code for android that connects to Nikon directly through wifi?
I tried to download the code of the qdslrdashboard but there is only usb conenction!
you'll be my lifetime saver
Regards
Posted: 01 Apr 2015, 11:56
Marckov85 wrote:Dear Zoltan,
Regards
You should open a new thread. qDslrDashboard is not open source.
Posted: 02 Apr 2015, 03:25
by xingr8
hubaiz wrote:This function is available from start with the 'Nikon wireless' button
I am unable to establish a wireless link to my D7200 at all. With a USB cable from my Android phone (Galaxy Note 4) qDD identifies my D7200, but none of the controls seem to work. Do I assume correctly that I need to wait for a new version of qDD that supports the D7200 before I should expect any more of qDD to work?
Posted: 02 Apr 2015, 04:49
The D7200 is not yet support as Nikon didn't release the documentation for it.
If you can give me the USB vendor and product ID I may add initial support.
You can get this after connecting to a desktop machine and checking out the camera USB properties in device manager or with 'dmesg' or 'lsusb' on Linux
Posted: 04 Apr 2015, 11:40
by Marckov85
Dear Zoltan,
after conencting my nikon d5300, and if i minimize the qdashboarb(on android), i want the pictures taken by the cam to be automatically downloaded to sd card.
Is that option available? (coz right now when i maximize the qdashboad app then the pics are being downloaded to phone...)
Posted: 04 Apr 2015, 22:02
by xingr8
hubaiz,
Sorry it has taken me so long to get back to this. Sometimes the day job gets in the way.
I have hooked up the the D7200 by USB with my Windows 7 PC and found it using Device Manager. There are a large number of items under the "Details" tab, but none specifically "USB Vendor" or "Product ID". The closest ones are:
Device description D7200
Hardware Ids USB\VID_04B0&PID_0439&REV_0100
Compatible Ids USB\Class_06&SubClass_01&Prot_01
USB\Class_06
Device class guid {eec5ad98-8080-425f-922a-dabf3de3f69a}
Driver key {eec5ad98-8080-425f-922a-dabf3de3f69a}\0014
Manufacturer Nikon Corporation
Physical Device Object name \Device\USBPDO-8
Parent USB\VID_0451&PID_8043\300108497AA3
Siblings USB\VID_046D&PID_0825\1EC9E6A0
Matching device Id usb\class_06&subclass_01&prot_01
There are many more, so let me know if I have not hit on the ones you need. Hope that helps.
Posted: 05 Apr 2015, 06:22
xingr8 wrote:Hardware Ids USB\VID_04B0&PID_0439&REV_0100
Thanks this is what I need
(VID - vendor ID, PID - product ID)
Posted: 05 Apr 2015, 07:40
Here is a test build for Android:
It should work with the D7200 built in wifi and also live view should work. Please test it.
When Nikon releases the documentation I will add the D7200 specific property values
