1DS MK ll long shot question?
Posted: 01 Apr 2015, 11:54
by russellsnr
Hi,OK I no the 1DS MK ll is an old camera and has no live view however when I connect it with an OTG it shows up in DSLRDashboard it also downloads the images to the Nexus 7 but then that's it! cannot view images on the Nexus. Is there a way or an app that will allow me to view images on the pad, don't want to save them just view them.
Russ
Re: 1DS MK ll long shot question?
Posted: 02 Apr 2015, 12:23
Do you use DslrDashboard from the Play Store or qDslrDashboard from http://dslrdashboard.info/downloads/ ?
Posted: 02 Apr 2015, 12:52
by russellsnr
Hi, 2nd option used.
Posted: 02 Apr 2015, 13:11
Ok, what do you mean under you can't view the images? Did you enter the image gallery? Are the images there? After clicking on the image thumb does it load and display it?
Posted: 02 Apr 2015, 16:10
by russellsnr
It says or shows that images downloaded but then nothing the folder shows empty.
Messaged you.
Russ
Posted: 03 Apr 2015, 05:07
If it show the image then the image file should be there also as it loads from file.
What is in the filed 'Folder for local images' in qDslrDashboard settings?
