As the title already implies, I can't run qDslrDashboard on my RPi 2b. This is the error I'm getting when trying to start the qDslrDashboard.sh file:
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2# /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /lib/arm-linux-gnueabihf/libudev.so.1: no version information available (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libusb-1.0.so.0)
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.17' not found (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libusb-1.0.so.0)
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /usr/lib/arm-linux-gnueabihf/libgomp.so.1: version `GOMP_4.0' not found (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libraw.so.15)
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: /lib/arm-linux-gnueabihf/libudev.so.1: no version information available (required by /home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/libQt5SerialPort.so.5)Code: Select all
/home/pi/Desktop/dslr/qDslrDashboard_V0.3.4_RPI2/./qDslrDashboard: error while loading shared libraries: libudev.so.1: cannot open shared object file: No such file or directory
This is the uname -a output, just in case:
Linux raspberrypi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/LinuxAnyways, hope someone can help me with my little problem, thanks in advance!
