0.3.4 not running on Raspberry PI 2 NOT SOLVED? YES, NOW!
Posted: 27 Jan 2016, 09:08
				I had problems with 0.3.4.
I downloaded a fresh Jessie and buid a SD
I expanded the filesystem and ser video Ram to 512Kb
I downloaded qDslrDashboard 0.3.4 and the fix for Raspberry PI 2
I Expanded the basic package in home/pi the overwite qDslrDashboard with the fix.
I cd qDslrDashboard_V0.3.4_RPI2
I run ./qDslrDashboard.sh from the terminal
this is the result:
this is the result:
Result of sudo ./qDslrDashboard.sh is similar:pi@raspberrypi:~ $ cd qDslrDashboard_V0.3.4_RPI2/
pi@raspberrypi:~/qDslrDashboard_V0.3.4_RPI2 $ ./qDslrDashboard.sh
./qDslrDashboard.sh: line 26: /dev/nul: Permission denied
pi@raspberrypi:~/qDslrDashboard_V0.3.4_RPI2 $ This application failed to start because it could not find or load the Qt platform plugin "eglfs".
Available platform plugins are: eglfs (from /home/pi/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/plugins/platforms), linuxfb (from /home/pi/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/plugins/platforms), minimal (from /home/pi/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/plugins/platforms), minimalegl (from /home/pi/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/plugins/platforms), offscreen (from /home/pi/qDslrDashboard_V0.3.4_RPI2/./Qt_Libraries/plugins/platforms), linuxfb, minimal, minimalegl, offscreen.
Reinstalling the application may fix this problem.
pi@raspberrypi:~/qDslrDashboard_V0.3.4_RPI2 $ sudo ./qDslrDashboard.sh
 at all.
 at all.
