Connection ddserver qdslrdashboard windows10
dv03
Post by dv03 »
Hallo, please need help. I installed openwrt on TP-Link TL-WR710N v1 and konfigured wlan as client with dchcp as all other devices in same lan and adress range. Close firewall make it open for everything. installed usb -utils an could get answer with lsusb like : Bus 001 Device 002: ID 04b0:042c Nikon Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub . all seems ok. I installed all new packages needed for ddserver: libpthread_1.1.12-1_ar71xx; librt_1.1.12-1_ar71xx; libusb-1.0_1.0.19-1_ar71xx; uclibcxx_0.2.4-2_ar71xx and last version of ddserver_0.2-13_ar71xx.ipk . All ipk´s as last versions i could find. Now i installed on windows 10 the prog qDslrDashboard_V0.3.4_Windows_x64. It runs great with my nokia d3200 locked in on usb, but i could not reach the ddserver on the tp-link router. The correct ip-adress with default port is given in. Both - windows and ddserver do not recognizes each other. Where is the problem? what can i do? ddserver starts fine with ./ddserver start in /etc/init.d and gives out the message: Starting DslrDashboardServer (ddserver)
Saving PID 2337 to /var/run/ddserver.pid
DslrDashboard server started
root@OpenWrt:/etc/init.d#
thanks for any help
Germany
Re: Connection ddserver qdslrdashboard windows10
What is the OpenWrt system log saying after you connect your camera with USB to the WR710N (you can check in the administartion interface or with the logread command)?
Also what is the system log output after you try to connect from qDD to ddserver?
dv03
Post by dv03 »
thanks for answering. router system log: Sat Feb 13 12:08:40 2016 kern.info kernel: [ 147.235845] wlan0: AP 9c:c7:a6:7f:a8:cb changed bandwidth, new config is 2422 MHz, width 1 (2422/0 MHz)
Sat Feb 13 12:08:47 2016 kern.info kernel: [ 154.002676] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sat Feb 13 12:11:20 2016 authpriv.info dropbear[1421]: Child connection from 10.10.10.36:59059
Sat Feb 13 12:11:29 2016 authpriv.notice dropbear[1421]: Password auth succeeded for 'root' from 10.10.10.36:59059
10.10.10.36 is my windows 10 ip. I logged in with putty.
In windows eventvwr / windows logs / programmes - there is no log from qdslr. nothing . Also qdslr itself gifes nothing out. I wil try to reinstall the programm. Do i have stopped any necessary windows services? is my openwrt usb port configuration wrong? (1.1 why not 2.0)
Germany
If you set router as a client of other WiFi network you need also to set correct network bridging on your router.
Ddserver usually is available on eth and in this configuration WiFi IP and eth IP are usually different.
Don't know correct config. I've tired every setting that came to mind but nothing worked.
