DDB on TP Link MR3020
Posted: 03 Apr 2015, 09:24
Dear Zoltan, Dear Community,
First thank you for your amazing work and the way you are sharing it.
Unfortunatelly, Amaz*n disrupt the TP Link MR 3040 in France, and the price proposed by some resellers is indecent. So i tried to recycle my old MR3020 to install OpenWrt and DDServer. If it succeed, i will by a small usb battery.
I flash the MR3020 it with the openwrt-ar71xx-generic-tl-mr3020-v1-squashfs-factory.bin that i found on openwork website, and then use the openwrt-ar71xx-generic-tl-mr3020-v1-squashfs-sysupgrade that you provided by link some threads above http://dslrdashboard.info/phpBB3/viewtopic.php?f=6&t=90
When i connect to my router with my browser, i can see that there is a ddserver that is installed. I press on start just in case it was not started automatically.
But with qDslrDashboard on OS X (connected by ethernet to the router / ping to 192.168.1.1 working / able to use openwrt web interface) , i can't see any image from my EOS 550d dslr. When i click on Searching DDserver button, i have the message Searching for deserved that appear on the bottom of the screen but the message disappears seconds after, and nothing else is displayed.
(Note that when i plug my camera with usb to my MAC, the dashboard display the image from my camera).
How may i check that ddserver is running on the router with simple command lines ?
EDIT : add my camera reference to let user knows that this is working fine.
