Hi All
I'm trying to find out what will happen for sunset to night astro timelapses using the Nexus7 and QDSLR. One problem I have with the RamperPro is that when I go from sunset to night the ramper pro never gets to the full exposure I want. it will get to about 20 seconds and iso 1600. I had the end settings at 20 seconds and iso 4000 (but it never gets there and I don't think I can make the ramper pro go to the full iso)
So now I'm thinking of trying the Nexus 7 and QDSLR. On the LRTimelapse function I wonder if you can set it to reach the full end setting at a certain time? Like if I set the end exposure to be 20 seconds and ISO 4000, can I make that happen at say 2200 hours or midnight or, will algorithm ever find the end exposure once it fells it has it set correctly at 20 sec and iso 1000 like the ramper pro?
thanks, I hope I'm clear about this
Nexus 7 and QDSLR night
Re: Nexus 7 and QDSLR night
No you can't.
qDD will download the JPG image and analyze it and it will make the change according that. It will only do the change if the calculated value is higher/lower then the reference value.
What you can do is change the reference value manually and force qDD to make the change sooner/later.
