Sony A7II: timelapse, when shutter speed is close to interval, can't change shutter/ISO
Posted: 23 Mar 2016, 13:19
by chasg
Hi All,
I'm having a real problem when using a Sony A7II specifically for holy grail timelapse work (using the LRTimelapse module of qDSLRDashboard): when my shutter speeds get close to the interval (8 second shutter speeds, interval 10 seconds), I can no longer change the exposure values of the camera (the app can't do it, and I can't do it manually on the camera). It seems that the camera is somehow busy in those two seconds, too busy to allow alterations to shutter/ISO.
The problem exists when shooting with both an external hardware intervalometer, and when using the app's intervalometer.
I've of course set the camera to create raw+jpeg (smallest possible jpeg).
My Nikon cameras (connected via wifi using a modified TP-Link TL-MR3040) have no problems with alterations to their exposure values, even in the mere 2 seconds they have between end of exposure and next shot.
Does anyone know a way around this? Or perhaps the shortest number of seconds I need to leave so that the app has time to make alterations to the shutter/ISO values? I plan to test myself and, if I get a consistent answer, I'll note it in this thread.
Thanks for any help!
Chas
ps. the Sony timelapse app is not suitable for extreme holy grail timelapses, as it only adjusts shutter speed (and I need to ISO to ramp to cover the full day to night exposure values). Besides, it doesn't offer nearly as much control as qDSLRDashboard does.
Re: Sony A7II: timelapse, when shutter speed is close to interval, can't change shutter/ISO
Posted: 24 Mar 2016, 10:06
by GonzoG
With Sony it works differently. Camera software and qDD need more time and are busy longer.
With slower cards even with Nikon you won't be able to do any thing in few seconds after shutter close.
Also Sony is very slow with writing to memory cards - 2-3 times slower than Nikon and Canon.
Posted: 24 Mar 2016, 11:13
by chasg
Thanks for the info, I appreciate it.
I need to do a thorough test to see how long the dark frames on the Sony need to be. If it's over 5 seconds, I'll sell it (too bad, it's almost perfect for my needs).
