Holy Grail Stops Receiving images roughly an hour into Time-lapse
Posted: 04 Apr 2016, 20:26
Apologies if this has been covered elsewhere. I searched through the forums and couldn't find my exact problem anywhere.
Setup:
5DM3 - 1.2.3
RAW + SJPG
64 gig CF card
TP-link tl-MR3040
iPad Air 2- IOS 9.3
QDD - 3.5.1 but have seen this issue in previous releases.
I have been super pleased with my setup but recently have started doing some longer time lapses and I have run into this issue on my last 4 time-lapse trips. all using the LRtimelapse screen, Auto Holy Grail, Sunset. Auto direction on. everything works flawlessly for awhile and then 1 to 2 hours in I start getting blank preview files on the app. The exposure count keeps climbing for a while without any exposure data, but eventually the camera stops firing and will show the BUSY signal.
I've now gotten it down to a procedure of immediately disconnecting the usb cable from the TP-link. I then power cycle the router, close out the app and power cycle the iPad. After the iPad reestablishes a connection to the router I open QDD, plug the usb back in and reconnect (Usually loose 1-3 exposures during this connection). the previews then start coming back in and I can continue for another 1-2 hours.
Is there anything I have setup incorrectly that is causing the app to stop receiving preview exposures? I have two TP-link routers and get the same issue on both. I also got the same issue running the App on my iPhone so I am assuming this is an somewhere in the app.
Any help, or pointing me in the right direction would be greatly appreciated.
Thanks!
Setup:
5DM3 - 1.2.3
RAW + SJPG
64 gig CF card
TP-link tl-MR3040
iPad Air 2- IOS 9.3
Thanks!
