NMX Controller + QDSLRDASHBOARD via Ethernet
flow85
Post by flow85 »
Hy,
is it possible to connect the NMX Controller via Ethernet Cable to any Mac/Windows PC and control it via MOCO Feature in DSLRDASHBOARD?
regards
flow
Re: NMX Controller + QDSLRDASHBOARD via Ethernet
No, there is no ethernet port on the NMX.
You can connect with USB to your PC and control from qDslrDashboard (USB serial communication)
or you can control with Bluetooth.
flow85
Post by flow85 »
Ok, but will it work whith usb to ethernet adapter on both sides?
No it will not work.
