zoom in/out buttons not visible in LV on D750
FunPhoto
Post by FunPhoto »
Hi all,
I am pretty new to qDslrDashboard so there could be an operator error - but I don't find it! So - here it is: the D750 is connected via WiFi, LV works but I do not see these zoom buttons. I can change the zoom of the whole LV via the "camera properties display", but this cumbersome. Is there any toggle for those buttons?
Many thanks for your help in advance, Dirk
Re: zoom in/out buttons not visible in LV on D750
After you enter live view you will have a small LV button in the bottom right corner. With it you can switch the right button between the standard and live view button.
FunPhoto
Post by FunPhoto »
ok, yes - and the LV button says "LV". I found it - many thanks for the quick clarification. All the best, Dirk
