Canon EOS 550D (Rebel T2i) + EOS 5D3 - BUSY- / hangs
Posted: 04 Jul 2016, 13:13
Hello together,
I want to make a timelapse with my second camera, the Canon EOS 550D (Rebel T2i), but if i connected the camera with the TP-Link an the iPad the Camera shows on the display "BUSY" the whole time. If i discopnnect the camera the display are normal? I Postet this problem at first on Feb 2016.
I can start the qDSLR Version 3.5.1 with my EOS 550 D (Rebel T2i), but after 10 shots, controlled with the exnernal Pixeltimer, the camera shows "BUSY". From this moment the Camera hangs an makes no more photos. (RAW+JPEG are correct configured).
If i restart the wohle procedure again, i get the same result after 10 shots. I have re installed the last Firmware for the EOS 550D (Canon Rebel T2i) but i dont get any improvements. The shots 1-10 runs ( iPad, iOS 8.3, QDSLR 3.5.1 + TP Link TL-MR3040 + Pixel Timer TW282TX. This configuration runs with my EOS 5DM3 perfect.
I had tested the following configurations:
Canon EOS 5D M3:
QDSLR 3.5.1 + TP Link TL-MR3040 + Pixel Timer TW282TX + iPad 2 / iOS 8.3 + EOS 5D M3 -> runs perfect
QDSLR 3.5.1 + TP Link TL-MR3040 + Pixel Timer TW282TX + iphone 4s / iOS 8.4.1 + EOS 5D M3 -> doesn't runs -> camera hangs after 28 photos.
QDSLR 3.5.1 + TP Link TL-MR3040 + Pixel Timer TW282TX + iPad 2 / iOS 8.3 + EOS 550D -> doesn't runs -> Camera shoes "BUSY"
QDSLR 3.5.1 + TP Link TL-MR3040 + Pixel Timer TW282TX+ iphone 4s / iOS 8.4.1+ EOS 550D -> doesn't runs -> Camera shoes "BUSY"
Are the iOS 8.4.1 the Problem that I couldnt use it with my EOS 5D3 - or any problems with QDSLR 3.5.1 and the iPhone?
It was very great if I can use the iPhone, i can spend a lot of weight and space in my backpack for mountain-trips.
best regards
Canon EOS 5D M3:
best regards
