iphone 5s / iPad 2 : impossible to connect to my D300
Posted: 16 Apr 2015, 15:03
by HisteroH
all is in the title ;)
I bought the app 0.27 today
All seems running fine except that the app doesn't see any connected device on DDserver. I always have error message: "No DSLR device found on DDserver 192.168.1.1" and also "Failed to connect to Nikon wireless DSLR" when I click Nikon wifi button.
D300 reset to factory defaults, latest firmware
MR3040 seems to be running, updated and configured properly
iphone wifi ip is ok...
Any help or suggestions appreciated :)
...I really don't know what else to try...I'm stuck :(
Re: iphone 5s / iPad 2 : impossible to connect to my D300
Posted: 16 Apr 2015, 15:48
Check if the D300 is in USB PTP mode.
Pair your iOS device wireless with the MR3040 wireless.
Connect the D300 with the USB cable to MR3040 and turn it on.
Open the web browser and navigate to http://192.168.1.1
You should have the OpenWrt web interface. Under System->Software check that ddserver V0.2-13 is installed
Navigate to Status->System log
You should have something like this there:
Apr 16 17:27:53 Arduino kern.info kernel: [6159043.470000] usb 1-1.1.4.3: USB disconnect, device number 85
Apr 16 17:47:24 Arduino kern.info kernel: [6160214.910000] usb 1-1.1.4.4: new high-speed USB device number 86 using ehci-platform
Apr 16 17:47:24 Arduino kern.info kernel: [6160215.020000] usb 1-1.1.4.4: New USB device found, idVendor=04b0, idProduct=0430
Apr 16 17:47:24 Arduino kern.info kernel: [6160215.020000] usb 1-1.1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 16 17:47:24 Arduino kern.info kernel: [6160215.020000] usb 1-1.1.4.4: Product: NIKON DSC D7100
Apr 16 17:47:24 Arduino kern.info kernel: [6160215.030000] usb 1-1.1.4.4: Manufacturer: NIKON
Apr 16 17:47:24 Arduino kern.info kernel: [6160215.030000] usb 1-1.1.4.4: SerialNumber: 4302375
If this is ok start qDslrDashboard and press the 'Network' button.
If this does not found the D300 then try and long press the 'Network' button and enter 192.168.1.1 as IP address and press the 'Connect' button
Posted: 16 Apr 2015, 23:41
by HisteroH
Hi Hubaiz and thanx for your advices !
It appeared that usb was not set on PTP...I still have the no connected DSLR error with DDLserver and also no wireless Nikon found BUT after the error it starts LV.
I'm able to view shoot, most of the app seems to work but as I'm totally new to the app, I can't judge if it works as it should.
My log seems to have stop logging activity and I don't get the informations you gave me. Time logging is also wrong even if I've set it correctly in openwrt.
It looks like the log was kind of freezed at a certain time..
Here is my system log, please let me know what you think about it
Apr 16 13:43:04 D300 syslog.info syslogd started: BusyBox v1.19.4
Apr 16 13:43:04 D300 kern.notice kernel: klogd started: BusyBox v1.19.4 (2014-07-11 18:33:29 CEST)
Apr 16 13:43:04 D300 kern.notice kernel: [ 0.000000] Linux version 3.3.8 (hubaiz@xandroid64) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Jul 11 18:39:12 CEST 2014
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] MyLoader: sysp=fa89c804, boardp=69cd3b24, parts=31a09c82
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] SoC: Atheros AR9330 rev 1
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Determined physical RAM map:
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] memory: 02000000 @ 00000000 (usable)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Zone PFN ranges:
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Normal 0x00000000 -> 0x00002000
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Movable zone start PFN for each node
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Early memory PFN ranges
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] 0: 0x00000000 -> 0x00002000
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] On node 0 totalpages: 8192
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 802d61e0, node_mem_map 81000000
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] Normal zone: 64 pages used for memmap
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] Normal zone: 8128 pages, LIFO batch:0
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Apr 16 13:43:04 D300 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Apr 16 13:43:04 D300 kern.notice kernel: [ 0.000000] Kernel command line: board=TL-MR3040 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Apr 16 13:43:04 D300 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Memory: 29116k/32768k available (2115k kernel code, 3652k reserved, 406k data, 208k init, 0k highmem)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] NR_IRQS:51
Apr 16 13:43:04 D300 kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Apr 16 13:43:04 D300 kern.info kernel: [ 0.080000] Mount-cache hash table entries: 512
Apr 16 13:43:04 D300 kern.info kernel: [ 0.090000] NET: Registered protocol family 16
Apr 16 13:43:04 D300 kern.info kernel: [ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
Apr 16 13:43:04 D300 kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-MR3040
Apr 16 13:43:04 D300 kern.info kernel: [ 0.350000] bio: create slab <bio-0> at 0
Apr 16 13:43:04 D300 kern.info kernel: [ 0.360000] Switching to clocksource MIPS
Apr 16 13:43:04 D300 kern.info kernel: [ 0.360000] NET: Registered protocol family 2
Apr 16 13:43:04 D300 kern.info kernel: [ 0.370000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.370000] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.370000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Apr 16 13:43:04 D300 kern.info kernel: [ 0.380000] TCP: Hash tables configured (established 1024 bind 1024)
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.440000] ath: EEPROM indicates default country code should be used
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.440000] ath: doing EEPROM country->regdmn map search
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.440000] ath: country maps to regdmn code: 0x3a
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.440000] ath: Country alpha2 being used: US
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.440000] ath: Regpair used: 0x3a
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.440000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Apr 16 13:43:04 D300 kern.debug kernel: [ 9.450000] Registered led device: ath9k-phy0
Apr 16 13:43:04 D300 kern.info kernel: [ 9.450000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Apr 16 13:43:04 D300 kern.info kernel: [ 9.450000] cfg80211: Calling CRDA for country: US
Apr 16 13:43:04 D300 kern.info kernel: [ 9.460000] cfg80211: Regulatory domain changed to country: US
Apr 16 13:43:04 D300 kern.info kernel: [ 9.460000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.470000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.480000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.490000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.490000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.500000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.510000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Apr 16 13:43:04 D300 kern.info kernel: [ 9.570000] PPP generic driver version 2.4.2
Apr 16 13:43:04 D300 kern.info kernel: [ 9.810000] ip_tables: (C) 2000-2006 Netfilter Core Team
Apr 16 13:43:04 D300 kern.info kernel: [ 10.030000] NET: Registered protocol family 24
Apr 16 13:43:04 D300 kern.info kernel: [ 10.050000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Apr 16 13:43:04 D300 kern.info kernel: [ 10.050000] ehci-platform ehci-platform: Generic Platform EHCI Controller
Apr 16 13:43:04 D300 kern.info kernel: [ 10.060000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Apr 16 13:43:04 D300 kern.info kernel: [ 10.100000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Apr 16 13:43:04 D300 kern.info kernel: [ 10.120000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Apr 16 13:43:04 D300 kern.info kernel: [ 10.120000] hub 1-0:1.0: USB hub found
Apr 16 13:43:04 D300 kern.info kernel: [ 10.120000] hub 1-0:1.0: 1 port detected
Apr 16 13:43:04 D300 kern.info kernel: [ 10.150000] nf_conntrack version 0.5.0 (458 buckets, 1832 max)
Apr 16 13:43:04 D300 kern.info kernel: [ 10.390000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Apr 16 13:43:07 D300 kern.info kernel: [ 14.900000] device eth0 entered promiscuous mode
Apr 16 13:43:07 D300 daemon.notice netifd: Interface 'lan' is now up
Apr 16 13:43:07 D300 daemon.notice netifd: Interface 'loopback' is now up
Apr 16 13:43:07 D300 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Apr 16 13:43:11 D300 kern.info kernel: [ 19.320000] cfg80211: Calling CRDA for country: FR
Apr 16 13:43:11 D300 kern.info kernel: [ 19.320000] cfg80211: Regulatory domain changed to country: FR
Apr 16 13:43:11 D300 kern.info kernel: [ 19.330000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Apr 16 13:43:11 D300 kern.info kernel: [ 19.340000] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Apr 16 13:43:11 D300 kern.info kernel: [ 19.340000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Apr 16 13:43:11 D300 kern.info kernel: [ 19.350000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm)
Apr 16 13:43:11 D300 kern.info kernel: [ 19.360000] cfg80211: (5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm)
Apr 16 13:43:13 D300 kern.info kernel: [ 21.490000] device wlan0 entered promiscuous mode
Apr 16 13:43:13 D300 kern.info kernel: [ 21.540000] br-lan: port 2(wlan0) entered forwarding state
Apr 16 13:43:13 D300 kern.info kernel: [ 21.550000] br-lan: port 2(wlan0) entered forwarding state
Apr 16 13:43:15 D300 kern.info kernel: [ 23.550000] br-lan: port 2(wlan0) entered forwarding state
Apr 16 13:43:17 D300 authpriv.info dropbear[913]: Running in background
Apr 16 13:43:18 D300 auth.err sshd[919]: error: Bind to port 22 on 0.0.0.0 failed: Address already in use.
Apr 16 13:43:18 D300 auth.crit sshd[919]: fatal: Cannot bind any address.
Apr 16 13:43:20 D300 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Apr 16 13:43:20 D300 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Apr 16 13:43:23 D300 daemon.info dnsmasq[976]: started, version 2.66 cachesize 150
Apr 16 13:43:23 D300 daemon.info dnsmasq[976]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Apr 16 13:43:23 D300 daemon.info dnsmasq-dhcp[976]: DHCP, IP range 192.168.1.2 -- 192.168.1.24, lease time 12h
Apr 16 13:43:23 D300 daemon.info dnsmasq[976]: using local addresses only for domain lan
Apr 16 13:43:23 D300 daemon.warn dnsmasq[976]: no servers found in /tmp/resolv.conf.auto, will retry
Apr 16 13:43:23 D300 daemon.info dnsmasq[976]: read /etc/hosts - 1 addresses
Apr 16 13:43:23 D300 daemon.info dnsmasq-dhcp[976]: read /etc/ethers - 0 addresses
Apr 16 13:43:23 D300 user.info sysinit: setting up led USB
Apr 16 13:43:23 D300 user.info sysinit: setting up led WLAN
Apr 16 13:43:23 D300 user.info sysinit: setting up led LAN
Apr 16 13:43:23 D300 user.info sysinit: Starting DslrDashboardServer (ddserver)
Apr 16 13:43:23 D300 user.info sysinit: Saving PID 992 to /var/run/ddserver.pid
Apr 16 13:43:23 D300 user.info sysinit: DslrDashboard server started
Apr 16 13:43:24 D300 user.info syslog: DslrDashboardServer starting
Apr 16 13:43:24 D300 user.info syslog: Starting socket server on port 4757
Apr 16 13:43:24 D300 user.info syslog: Awaiting client connection
Apr 16 13:43:24 D300 user.info syslog: Starting UDP listener
Apr 16 13:43:24 D300 user.info syslog: join multicast group: 224.1.2.3
Apr 16 13:43:25 D300 daemon.info hostapd: wlan0: STA 4c:0b:be:07:5b:e6 IEEE 802.11: authenticated
Apr 16 13:43:25 D300 daemon.info hostapd: wlan0: STA 4c:0b:be:07:5b:e6 IEEE 802.11: associated (aid 1)
Apr 16 13:43:25 D300 daemon.info dnsmasq-dhcp[976]: DHCPREQUEST(br-lan) 192.168.1.204 4c:0b:be:07:5b:e6
Apr 16 13:43:25 D300 daemon.info dnsmasq-dhcp[976]: DHCPNAK(br-lan) 192.168.1.204 4c:0b:be:07:5b:e6 address not available
Apr 16 13:43:28 D300 daemon.info dnsmasq-dhcp[976]: DHCPDISCOVER(br-lan) 4c:0b:be:07:5b:e6
Apr 16 13:43:28 D300 daemon.info dnsmasq-dhcp[976]: DHCPOFFER(br-lan) 192.168.1.6 4c:0b:be:07:5b:e6
Apr 16 13:43:28 D300 daemon.info dnsmasq-dhcp[976]: DHCPREQUEST(br-lan) 192.168.1.6 4c:0b:be:07:5b:e6
Apr 16 13:43:28 D300 daemon.info dnsmasq-dhcp[976]: DHCPACK(br-lan) 192.168.1.6 4c:0b:be:07:5b:e6 MADSP3
Thank you for your help ! :mrgreen:
Posted: 23 Apr 2015, 12:55
by HisteroH
After a few tests in the app, it appears that the app is really buggy and unuseable for me.
I'm pretty sure that it's because my D300 isn't detected properly (see my log in my previous post)
I mean the app works, but when, for example, I try to change shutter speed, it won't keep de value, or set it to a wrong value. Actually if I want 1/80, I need to select 1/320 ...
BKT won't keep actual shuter speed values, and also can't be desactivated. So for HDR photography it's impossible to use.
To summarise, when I try to connect, I have to error message saying that there is no D300, BUT it connects anyway and starts de LV. I can access all the sttings, but when I try to fine tune, it sorts me wrong values or freeze the app
If someone has any idea on how I could detect properly my D300 I'd really appreciate !!
Posted: 23 Apr 2015, 13:17
The OpenWrt log dosn't help here.
Can you describe what are you doing/changing step by step?
Can you try it without LV and with LV enabled?
