Can I use the Dynamic Perception NMX controller together with qDD
Posted: 07 Oct 2016, 16:37
by Miksel
I read on the dslrdashboard.info website that the NMX controller from Dynamic Perception can be used together with the qDD. Is that still the case? Are there other controllers which work togehter with the qDD?
Re: Can I use the Dynamic Perception NMX controller together with qDD
Posted: 08 Oct 2016, 07:34
by GonzoG
Yes, you can use NMX with qDD (maybe ever good clone of it - I found few on ebay, but there is no warranty that those will work), because qDD uses Bluetooth to connect with NMX.
Other controllers won't work because there is no implementation for them in qDD.
Posted: 08 Oct 2016, 09:01
by Miksel
Thank you for the answer! Can you suggest a good introduction about how the nmx controller, camera, motion (slider etc) work together with the qDD? I did not fully understand it. Take care, Michael
