USB OTG Support on IOS Device
Posted: 20 Apr 2015, 16:30
by loybuckz
Hi there! I would like to know if the USB OTG is supported on IPAD Mini. I currently have a Nikon D700, Ipad Mini and a USB OTG for the ipad.
Thanks in advance.
Re: USB OTG Support on IOS Device
Posted: 22 Apr 2015, 08:03
by GonzoG
You cannot have USB-OTG cable for iPad because iPad does not have USB port.
Alse the only way you can conect camera and USS qDD iż WiFi - built in camera or wireless router like TP-Link TL-MR3040.
Posted: 06 May 2015, 23:34
by lcheung123
I have two OTG cables from two sources, meant to use them on my samsung note 2 and another android smart phone. However, with DSLRdashboard one OTG cable works and the other doesn't, but both work well for data transfer between laptop and note 2. Do not know why.
Posted: 07 May 2015, 18:31
by GonzoG
I don't know how you can use USB-OTG cable to connect samrtphone to computer. It is physically impossible because USB-OTG cable has a socket on one end not a plug which you need to plug it into computer USB port.
USB-OTG cable/adaptor looks like this:
One of the cables you bought - not working one - is definitely standard USB cable.
