RAVpower routers solution - HELP needed
Posted: 06 Jan 2017, 05:10
by humann
I am looking for RP-WD01 router to work with DSLRdashboard. I found this on GitHub related to RP-WD01 but have no clue what to do with it !?:
https://github.com/wingspinner/HooToo-T ... T/issues/6
Anyone know how to fix this?
RP-WD01
(here is the manufacturer page https://www.ravpower.com/ravpower-rp-wd ... -bank.html )
I found for this model solution.
RP-WD02
(here is the manufacturer page https://www.ravpower.com/downloads-65-80000-033.html )
https://wiki.openwrt.org/toh/ravpower/rp-wd02
and none for this one. Did not test this as well.
RP-WD03
(here is the manufacturer page https://www.ravpower.com/rp-wd03-filehu ... outer.html )
Thanking you in advance
Re: RAVpower routers solution - HELP needed
Posted: 11 May 2017, 07:18
by Ed Barnacle
I'm also looking to use a Ravpower Filehub Plus (https://www.ravpower.com/downloads-81-65001-001.html) with qDslr. Has anyone got any info on how to get one working?
Posted: 07 Aug 2017, 05:27
by Ed Barnacle
Anyone....?
Posted: 08 Aug 2019, 09:11
by 206teufel
I can confirm that I run DDServer and qDslrDashboard without problems on the RavPower WD-003.
First install OpenWrt, it is described on OpenWrt.org or here: https://wiki.ziemers.de/doku.php?id=wik ... ower:start
Then you can use this: https://goo.gl/h6YzPh to install DDServer, worked for me perfectly.
Thanks to all contributing to this project
